Advice on drilling my pipe
Old Mar 2, 2008 | 10:30 PM
mudjunkie's Avatar
Default RE: Advice on drilling my pipe
If you need the spark arrestor for legality reasons, then I would not recommend drilling the exhaust. I drilled out the baffles and had a friend weld in a new tail piece, but I did not realize at the time that I drilled through the spark arrestor baffle and now I am not legal. I will have to replace my exhaust to pass a yearly vehicle inspection before I will be able to ride this summer. If I wre in your position, I would save the cash for a new exhaust system, then the jetting andairbox can be done after you have the exhaust.....as jetting and airbox mods are relatively cheap to do compared to the price of the exhaust.
Old Mar 3, 2008 | 12:11 AM
Flood_33's Avatar
Your probaly right mudjunkie , i will probaly just wait till i can drop a few bills on an exhaust.. Anyone have a powercore 4 exhaust? If so how is it?
Old Mar 6, 2008 | 05:14 PM
VORTECkaw's Avatar
AgoosSSwhere did u find that 300 exhaust i just looked on ebay and cant find any 300 exhausts the only thing that comes up is the billet tip. Thanks
Old Mar 7, 2008 | 01:57 AM
AgoosSS's Avatar
VORTECkaw, the one I saw for $10.00 ended. I don't know if someone bought it or not. I have seen many on e-bay in the $9.00 to $45.00 range. I just did a quick look and didn't see any right now. Just wait a little because they are for sale all the time.
Flood_33, my experience with the FMF Powercore 4 was with a FSW head pipe. A riding buddy also has that set up. I currently have a FSW full system.The FMF is a nice unit. If I had the S model and had to have a full aftermarket system I would go with the FMF header and exhaust. FMF does not make the header for the 300. The only other one I can compare to is the Big Gun. The FMF is much better qualityIMO. I don't have any experience with the Muzzy but it looks and sounds like from others to be a good unit. I still have to repeat that the biggest bang for the $ is the FSW header and 300 exhaust with the but plug removed. As good power wise as any system I have tried and you don't have to repack it.
Old Mar 7, 2008 | 01:59 AM
Flood_33's Avatar
Thanks for reply . Could i run FMF pipe with stock header? Surely that is okay to do....
Old Mar 7, 2008 | 02:42 AM
AgoosSS's Avatar
Hopefully someone else will chime in and answer. I think there is a difference in length between the 300 head pipe and the 250S. I think the S has a shorter pipe, so if you get an FMF for the 300 it may not fit. I think I recall someone using a stock 300 header with an FMF exhaust on the S model. Stock 300 headers are also on e-bay often and cheap. But I would never go that rout. Also there has been documented fit problems with the FMF exhaust and FSW header. If you go that rout, let Jerry at FSW know you are using an FMF and he will make sure it fits up. The Sdoes need a different exhaust to help it breath but with my experience with the 300, the header gives the most notable power gains.
Old Mar 7, 2008 | 03:08 AM
Masson's Avatar
ORIGINAL: Flood_33
Well at this point and time i couldnt rejet a soft taco... i'm learning all this stuff... so one of these days i'll ask about rejetting...
LOL after I read that I just about fell on the floor from laughing. I pictured a raged guy and soft taco with a needed and a couple of jets pounding on a table.
Trust me once you read the "How To's" its not as bad. Plus you have this great forum to help you. If you know any friends that have done jetting it would be great to have them at you side.
Here is a great write up:
http://www.hmfengineering.com/forums...ead.php?t=1617
-Nick
Old Mar 7, 2008 | 11:25 AM
Flood_33's Avatar
Hah! Ya these folks have been very helpful so far!!!
Old Mar 7, 2008 | 03:13 PM
wedge's Avatar
yes the header lengths are different for the 250s and 300 so if you get the 300 stock pipe you need a 300 head pipe to go with it(unless you can weld) same thing can happen if you buy after market stuff; its close, so pay close attention to those part numbers.
incabiker
Feb 10, 2016 12:35 AM
skylinegtst
Mar 19, 2007 04:14 AM
espacef1fan
Aug 28, 2006 08:03 AM
LordVngr
Aug 4, 2006 10:04 PM
Richt
May 20, 2006 01:33 AM
