9000 RPM IS THAT IT ?????
Old May 22, 2008 | 10:25 AM
big lou's Avatar
Default 9000 RPM IS THAT IT ?????
can these bikes do 11.000 rpm an hold to geather ?????
Old May 22, 2008 | 10:52 AM
Default RE: 9000 RPM IS THAT IT ?????
i think the rev limiter is set at 10,500... but go a head hold it there and let us know what happens.
Old May 22, 2008 | 11:40 AM
big lou's Avatar
i feel the power fade at about 9000 do they make a cdi box that it with make more power up at 10-5.
Old May 22, 2008 | 11:53 AM
Truckman's Avatar
go get a kx450F if you want to rev it to the moon ....this motor isn't made to produce power at that rpm level....no matter what you do to it.
The cams are what hold it back.remember, a kx250F can rev to the moon to build power but from that comes a price.....rebuilding the head.I think Kawi recommends 40-60 hours for a head overhaul.How many miles would that be?3000? that would get old real fast.
Old May 22, 2008 | 01:25 PM
kgwld1's Avatar
Even with the cam change the timing is more of the problem.
Kevin
Old May 23, 2008 | 12:29 AM
shaydara's Avatar
7500rpm is as far as I've taken it to. I just don't see the point to rev the **** out of a 250 enduro. On the road I hit between 5000 and just over 6000rpm. On the highways I will sit on 5500-6000rpms nicely cruising along, the KLX seems to like that spot (6000) and if traveling long distance I can sit on that all day no problem and the KLX just smiles back at you.
Cheers!
rkelley548
Jun 17, 2009 07:43 PM
kazerotor
Jul 11, 2007 09:40 AM
hammerbyte
Jan 10, 2006 02:24 AM
Bluebeast
Oct 26, 2005 07:14 PM
BigMike
May 30, 2005 08:09 AM
