351 installed
Old May 21, 2009 | 01:21 AM
QZ87's Avatar
Default 351 installed
i installed my 351 cylinder well worth the money very pleased with the result
A+++++++ for Bill
Old May 21, 2009 | 01:32 AM
revtor's Avatar
allright, Im about to do this as well.. dont mind me picking your brain for a sec...
-what did you use for sealant on the headgasket?
-did you clean all the soot off your head before bolting it back down?
-how are you planning on breaking it in?
-how did you change your jetting?
thanks alot, please come back with a ride report!
~Steve
Old May 21, 2009 | 02:15 AM
neilaction's Avatar
Sweet.
How long before I give in?
Old May 21, 2009 | 02:29 AM
QZ87's Avatar
what did you use for sealant on the headgasket? i used copper spray from napa
did you clean all the soot off your head before bolting it back down? yes i used scotch brite pads and then clean all surfaces with thinner and try not to touch anything
how are you planning on breaking it in? i let it run up to operating temp then i let it cool then run it around a little at 1/4 throttle then again at no more then half
This has always worked for me but everyone has there own opoin on this subject
how did you change your jetting i talked to a guy on here and he was running the stock carb with the 351 kit i used 132 main 35 pilot needle in middle clip air screw 2 turns out
Old May 21, 2009 | 02:33 AM
QZ87's Avatar
bike has alot more bottom end power it needs one of them pumper carbs u can lug it down more in tight spots front end comes up alot better
Old May 21, 2009 | 02:41 AM
Bake's Avatar
I run the stock carb and stock pipe and my baseline is:
40 pilot, airscrew 1 turn, DJ needle full lean, 132.5 MJ
Old May 21, 2009 | 05:40 AM
MotoFan's Avatar
Hmmm the aussie dollar is becoming stronger against the Greenback again ... could
be worth it very shortly ...
D.
Old May 21, 2009 | 07:39 AM
neilaction's Avatar
Originally Posted by MotoFan
Hmmm the aussie dollar is becoming stronger against the Greenback againD.
Indeed it is.
I can see the credit card copping a hammering soon.
Old May 21, 2009 | 01:04 PM
revtor's Avatar
Thanks for the answers QZ87... !!!
have fun with your new machine!
~Steve
Rosed
Jul 17, 2013 02:04 AM
GaryC
Nov 1, 2011 01:45 AM
jhoffy22
Jun 26, 2011 12:02 AM
Ramjet
Mar 8, 2010 02:35 AM
jpaul310
Sep 2, 2009 12:33 AM
