300 piston kit from China
Old Jul 24, 2020 | 06:34 AM
AussieCheech's Avatar
Default 300 piston kit from China
Did some googling and came across this kit. I do recall some of you taking about a kit from China. Is this it? Will it fit my 2018 KLX? If they are the right fit and are ok, it sure would be a cheap way to gain an extra 20%.
https://www.ebay.com.au/i/293540150308?chn=ps&norover=1&mkevt=1&mkrid=705-139619-5960-0&mkcid=2&itemid=293540150308&targetid=95163731028 4&device=c&mktype=pla&googleloc=9069290&poi=&campa ignid=9772796532&mkgroupid=100117148296&rlsatarget =aud-786643580846la-951637310284&abcId=578876&merchantid=114604499&gcl id=Cj0KCQjw6uT4BRD5ARIsADwJQ187_s64LRYYQvMLF4bFf5R-28FaeHmUSdYd_hrJjPw4GRgoovX0hH8aAtGaEALw_wcB
Item specifics
Condition: New Fits1: Kawasaki KLX250 1993-2014 Cylinder Wall Material: Ceramic Fits2: Kawasaki KLX300 1996-2007 Surface Finish: / OEM: KLX250: 11005-1817/11005-0112 & KLX300: 11005-1983 Manufacturer Part Number: Does not apply Model: KLX250 250R 250S 250SF / KLX300 300R Brand: AHL Cylinder Surface Material: Aluminium Alloy Warranty: Yes Country/Region of Manufacture: China
Cheech
Old Jul 24, 2020 | 05:03 PM
Klxster's Avatar
If your signature line is complete, you still have one more leap in performance available before you look at a BB kit. And that is to add a Megabomb or Powerbomb header to your PC4 and up the main jet to a DJ144 or K158 ( to make your lidless CVK setup the correct setup for a full performance exhaust..)
You will gain a strong, linear, power band that pulls hard all the way to redline.. (10,500 rpm)
Old Jul 24, 2020 | 09:08 PM
Item specifics
Cheech
Reinigelf did the 300 kit. I haven't got time to install mine yet due to a lousy summer with a hosed up knee making work on anything very difficult. Here is one of his posts. There are others here and at the ADVrider forum that have done the kit without problem and good results.
Originally Posted by reinigef
Yes I have been running the AHL Tong Tong cylinder since last late summer/fall. She broke in nicely and is running strong, no issues whatsoever. Some have said gaskets don't line up with water passages but mine did. Just double check.
Old Jul 25, 2020 | 12:07 AM
Was re-jetted to suit the pipe and lidless, so I don't think I can get much more there. I did some research on megabombs. Not sure I want to spend money there.
@reinigef is yours still going strong? Thanks for the info 678
Old Jul 25, 2020 | 03:02 AM
I used to think big bores were trouble until I did one on my KLX650 and have put around 35,000 trouble free miles on it. Seems in most cases there is no replacement for displacement. I just am avoiding high compression set ups and I don't believe the AHL 299cc is much more if any than the stock 250.
Old Jul 27, 2020 | 04:20 PM
reinigef's Avatar
Yes Aussie Cheech, AHL Tong Tong cylinder and piston are doing great. I have not had any reason to take her apart so I don't know what it looks like inside. Other than wider foot pegs, best money I've spent on the bike. FYI I am running a 36 mm Mikuni pumper carb and not the stock CVK carb. I'm not sure if the intake setup is the same for a fuel injected v.s. a carbed model however. This could be an issue... Perhaps someone here knows if they are the same or not.
Old Aug 2, 2020 | 09:36 PM
InspectorJim's Avatar
KLX678. It was determined by one of the first people (sorry, don't remember who), the one that determined the head gasket was wrong and the lower cam chain guide bolt needed shortened that the AHL 300 kit was a lower compression than stock.
Old Aug 2, 2020 | 09:59 PM
The head gasket extended into the water jackets a bit so some chose to buy a Kawasaki gasket. As for compression I don't know. It had been mentioned in other threads on the AHL kit, that the lower bolt needed shortened I believe around 4mm. All well known. Regardless of any of that, the kit adds significant power per those who have done them.
Old Aug 2, 2020 | 10:17 PM
I think the original thread I was referring to was from ADVRider. I ran the 300 cylinder for around 1500 miles last summer before switching to 351 over the winter. The 300 did add some boost , but nothing like the 351 did.
Old Aug 2, 2020 | 10:20 PM
Also to note. When I took the 300 kit off it looked perfect after 1500 miles. I have it and my original 250 cylinder in case I ever need to switch back, but I wouldn't hesitate to put the 300 back on with the same rings and all.
LearjetMinako
May 17, 2026 01:31 PM
Biddy56
May 21, 2018 01:13 AM
cpr1
Jul 6, 2015 09:50 PM
cpr1
21
Feb 9, 2013 08:15 AM
djchan
Jul 7, 2012 04:55 AM
