2006 klx 250 carb replacement
Old Jun 26, 2019 | 03:45 PM
Hericame's Avatar
Default 2006 klx 250 carb replacement
I see tons of replacement carbs but only have one throttle hole (pull I guess). My old carb has both a push and pull cables holes.
Any idea on replacing this old keihin cvk 34
Old Jun 26, 2019 | 08:31 PM
Brewster's Avatar
The second cable on the stock setup is a safety feature. All of us that have replaced the Keihin with a pumper simply eliminate the extra cable. The Mikuni TM33 and TM36 pumper carbs are the most common replacements. Bill Blue sells a TM33 that is bored to 34mm.
One of the stock throttle cables can be routed to work with the Mikuni's but a custom made 2" longer cable will make things a lot easier.
Ride on
Brewster
Old Jun 29, 2019 | 03:30 AM
dogmeat's Avatar
a bicycle brake cable works for a throttle cable. they come with 2 different type ends swaged to the cable & you cut one off for you application. one end will probably fit. the other you have to make. I've made ends from brass rod stock, but sometimes its nice to have stuff already to go. the good source is Flanders:
Flanders Cables for Mechanical Control, throttle cables, brake cables, automation control cables, custom robotic control cables
I use my soldering iron for small cables and propane torch for bigger ones. if you want to make a "solder pot" for dipping, get yourself a iron cap for iron plumbing pipe.
Old Jun 29, 2019 | 03:55 PM
reinigef's Avatar
D Pippen website has good carb info and specifications for a longer throttle cable.
KLX250S Home Page
Old Mar 8, 2024 | 09:43 AM
Andrew250S's Avatar
Default Carb Replacement newbie
Hi guys,
I have an '09 KLX250S. Would this https://mikunioz.com/shop/mikuni-vm-...v=13b249c5dfa9 be a suitable replacement, or is there one more specific that's an easy fix?
Old Mar 8, 2024 | 11:31 AM
The flat slide w/accelerator pump, TM36-68 is commonly used. https://mikunioz.com/product-categor...v=13b249c5dfa9 It can be had with the right jets. For more information on it you can do a search here and also go to D Pippin's web site click here He has the base jetting for the carb too. I found the jetting also matched up to another rider's jetting too. Kind of verifies it a bit. I trust Doug's information, it hasn't failed me so far. I did the stock carb rejetting per his information and it was plug and play.
One I wondered about was using the TM36-4 without the pump. Using the VM and TM on off road two strokes and on the Yamaha 500s in the 70s-80s makes me curious if it would work.
Dragon351
Apr 14, 2018 04:21 AM
Mar 5, 2017 05:27 AM
texbb
Jun 14, 2016 10:00 PM
djchan
Dec 20, 2012 06:03 PM
doitinthewoods
Jul 3, 2008 09:13 PM
