1200 miles
Old Mar 9, 2009 | 04:54 PM
BouncingRadical's Avatar
Default 1200 miles
Did any of y'all take it in for the 1200 mile tune up? If so how much did it cost. I'm pretty apt with a wrench is hard to do it yourself?
Old Mar 9, 2009 | 05:16 PM
I had mine in at 1000 or 1500 I can't remember, but I took it to the dealer because the tapping noise was a little loud, they changed out the Cam with its ACR, and then at 2500 I had the cam chain adjuster replaced all under warranty. While it was in both times I had the valves checked. They didn't charge me for checking the valves since they were already doing the work.
Old Mar 11, 2009 | 01:35 AM
f1rocco's Avatar
Lube your key switches and/or complain to get new ones...Or both I guess..
My 09 suckde..Well I do keep it outside naked to snow and iceo..Ignition key cylinder locked up......Its under warranty so Id complain about something If I had 2 do it again....I went out of pocket for about $200 squid..For new locks installed..I didnt want to wait and thought I could do it myself...Double wrong.....
If your not the best at doing things yourself....Screw it let the dealer fine tune it...
Rocco
Old Mar 11, 2009 | 02:19 AM
warski's Avatar
I didn't take mine in.
The first service was due at 600 miles. I just went through the periodic maintence chart in the owner's manual and completed all of the items. Most of them are/were inspection items. Basically, they change the oil/filter, check and see if anything is leaking, and check bolts to make sure they're tight. I think they quoted me somewhere around $135-$150. By the time I got to 600 miles, I was on the third oil/filter change. I was not about to pay them ten times what it costs me to change the oil...
Old Mar 13, 2009 | 07:52 PM
Yeah I've changed the oil, thats no problem. The 1200 mi checks alot of internal stuff that I don't have the equipment for, or have never done. I'm definitely going to take mine as I just checked my mileage (I record my miles and fill ups) and my MPG has tanked 10MPG from 70 to 60, and I have been getting misses every now and then while I am riding. I hope its not to expensive, I don;t start work till June :-/
Thanks for all y'alls input!
c10
ZZR 1200
May 31, 2008 05:31 PM
idwin
ZZR 1200
Feb 2, 2007 01:21 AM
EMS_0525
Jan 23, 2007 07:06 PM
idwin
ZZR 1200
Oct 9, 2006 09:07 AM
Allen
Aug 14, 2006 09:33 PM
