09 KLX250 valves
Old Sep 27, 2015 | 01:17 PM
MaximusPrime's Avatar
If I was that far in the motor and the valves were at the tightest tolerance, I'd go ahead and re-shim to the middle of spec (if not a bit further).
Then you are definitely good for another 7500mi, at the least.
The bike will start a little easier and run better too.
Going from checking the valves to changing the shims is another level of wrenching.
It's not hard, it just requires care and patience.
I'd done a few screw type valve adjustments before doing this bike, I was a tad nervous, but it came out fine.
FWIW, at 47,000mi I've adjusted the valves twice over five checks, although I'm about to go back in and check them again.
Old Sep 27, 2015 | 04:51 PM
I wouldn't get too shook up if at the upper clearance amount. It was critical with shim over bucket because they could spit a shim if the valves floated at high rpm, but that was eliminated with shim under bucket. Unless they're more than a thou out the top it is almost not worth bothering - per the guys I worked with at a Kaw/Yam/Honda shop when I asked about it with two valves at a thou over the top limit.
That said, if you're in there why not reshim, mine was a 4 cylinder, more complication. Just don't shim to the lowest clearance, they tighten up as the valves seat or wear into the seats.
Old Sep 27, 2015 | 06:08 PM
Zombie Toes's Avatar
Yeah I went ahead and reshimmed it while I was there. It would have bothered me knowing it was that tight and about to be out of spec. Now it won't eat away at me that I left it there. Haha only draw back is that my valve cover is leaking now. Get to tear it back apart and adjust that a bit!
Zombie Toes
Sep 24, 2015 07:34 PM
thecount
Jun 9, 2006 08:42 AM
M1A1
Apr 17, 2006 07:07 AM
quiklilrex
Aug 22, 2005 10:10 PM
ntence
May 24, 2005 12:33 AM
