07 klx250s carby/jet question
Old Nov 5, 2012 | 01:56 PM
Originally Posted by Tri-Polar
However you said 2206 is needed for the big bore, but also good for without it. Is this a typo?
I think the 2206 was originally design for the KLX300, for which the KLX250 has the same carb. As TNC says, many riders have used the 2206 from "mild to wild." I used the 2206 with the stock bore before 351 kit. It's just my opinion it's probably a better model for big bore compared to the 2152. I have no proof, just an assumption.
Old Nov 5, 2012 | 03:50 PM
Originally Posted by IDRIDR
Thad -
Do you think the OP probably wants some input from the other Aussie members with DJ kits to get things close on the first go? Seems those guys run much larger jets.
Yes, probably a better idea. With those guys being on the wrong side of the planet, it's likely they have everything upside down there.
Old Nov 6, 2012 | 12:19 AM
klx4me's Avatar
Judging by the link you provided, the 2152 is better suited.
As previously mentioned, I didn't buy a DJ kit as you end up with a whole heap of jets you don't need. Here's what I've installed on my Aus '08 250.
Main jet - #138 Kawa part # - 920631015
Pilot jet - #40 part # 920641108
2x shims under stock N1RX needle - part # 920221003
It has not had the slide hole drilled out & the mixture screw is 2 1/2 turns out. No snorkel on the airbox lid. It does pop under decel which doesn't worry me. I find that applying a little throttle stops it. I also removed the deicing circuit (less potential coolant leak points).
I haven't touched this set-up since installation (over 9 months). It needs choke for a cold start and it fires straightaway on a hot start.
Old Nov 7, 2012 | 12:47 AM
Tri-Polar's Avatar
So today i took out the dial a jet. In that time the new plastic tank showed up. However the "on" barb fitting on the tank is lower then the barb fitting to the fuel tap and the fuel hose isnt flexible enough to make the correct bends and crimps itself. How can i fix this issue instead of running on the reserve circuit?
Old Nov 7, 2012 | 09:23 PM
Sharan's Avatar
Very similar setup here, difference is #38 pilot jet and 2.8mm slide hole drilled. Mine also does pop on decel, but it did so as stock. Had lid off, but the noise was too much for me old ears, lid on and no snorkel now. Thinking about putting KDX snorkel in, but I cannot find one anywhere in Oz.
Old Nov 8, 2012 | 03:42 AM
Tri-Polar's Avatar
I just ordered mine from power sports plus. Dont get the 2 day express post. Paid $45 to ship a oil filter cover and 5 o-rings, im still waiting for it a week later...
Old Nov 18, 2012 | 03:57 AM
WestOzKLX's Avatar
Hi TP. Give me a call and I'll run you through it all. I'll send you some new fuel hose for your new tank, if you like, (I can stretch to the price of a stamp for a fellow rider. ) I'm in Perth (no DL saving, 0403800887.)
Old Nov 18, 2012 | 10:05 AM
  #28
Tri-Polar's Avatar
Thanks for the offer mate. I havent updated recently. But i ran the tank on reserve, so no dramas there. As for the carby, i cleaned out all the jets and am running it on 3 1/2 turns out. When cold its a pig to ride but once warm it seems to go alright. I dare say its time for a rejet anyways.
fgk228
Nov 5, 2009 04:42 AM
fgk228
Oct 18, 2009 01:40 PM
rsixsta
Apr 9, 2008 02:09 PM
pointman74
Sep 12, 2007 12:11 PM
