07 250s speedo not working right
Old Aug 4, 2012 | 08:55 PM
teamgreenrider91's Avatar
Default 07 250s speedo not working right
dumped the bike for the first time today in some really tight trails. nothing hard more just lost my balance when i came to a dead stop and laid the bike on its right side. anyhow now my speedo isnt working right my rpms seem to be right on the money but when i was doing between 50-60 mph with my friends riding next to me my speedo was bouncing between like 30-40 and wont stay steady even though im holding steady throttle. any ideas on if i should replace the cable or the pickup at the hub or just finally suck it up and buy a vapor kit for it?
im kinda lost on this one so if anyone can offer some help thatd be great
Old Aug 4, 2012 | 08:58 PM
and if i should just buy the vapor kit i was told to get one for a klx 300 so would this be the right one?
KLX300 KLX 300 TRAIL TECH STEALTH VAPOR COMPUTER KIT | eBay
Old Aug 4, 2012 | 09:00 PM
CousinLarry's Avatar
Probably the cable. I've broken mine about seven times.
Old Aug 4, 2012 | 09:30 PM
ii pulled it off from where it mounts to the gauge and it doesnt appear to be broken at all and same thing down at the hub
Old Aug 5, 2012 | 04:12 PM
bump
ive decided im just going to go with the trail tech kit as ive been wanting one anyways. but i want to make sure that the one im looking at will work being that they dont actually make a kit for the 250s
Old Aug 6, 2012 | 08:18 PM
rgoers's Avatar
Crimping the cable sheath will cause similar results as you are experiencing.
Old Aug 7, 2012 | 06:26 PM
i swapped it out with a brand new cable and its still doing the same thing
Old Aug 7, 2012 | 08:17 PM
wildcard's Avatar
sounds like the pick-up at the hub is busted.
Old Aug 7, 2012 | 08:50 PM
rgoers's Avatar
There's friction at work somewhere. Probably at the hub or the display. May have put a slight bend in where it connects at either end - that would cause a wobble, and hence, a bouncing needle.
Old Aug 8, 2012 | 04:46 AM
MaverickAus's Avatar
DaViD
Oct 29, 2009 01:23 AM
SCANNYMAN
Jun 12, 2009 09:05 PM
KFX Rida
Jun 4, 2009 04:54 AM
carl
May 27, 2007 10:11 AM
eclipsehunter2001
Oct 26, 2006 12:24 AM
