02 klx300 wheels on klx250s
Old Apr 1, 2016 | 02:39 AM
toomanytoys84's Avatar
Default 02 klx300 wheels on klx250s
Probably been asked before..looking at a klx300r for parts and want to know if those wheels will swap to my klx250s
Old Apr 2, 2016 | 11:33 AM
Maybe on an 06-07, but the front won't work with the speedo drive on the 09. The electronic drive is different from that of the mechanical.
Old Apr 2, 2016 | 12:08 PM
Ok. I have an 06. I just picked up the bike with a blown motor for 300 dollars. I am going to tear down the bike and see what the motor looks like if its not bad, then maybe I'll fix the bike, if not I am just going to use the parts, header, wheels, ect. then try to part off the other stuff.
I was wondering if the klx300 suspension components are an upgrade as well.
Old Apr 2, 2016 | 02:02 PM
Ruggybuggy's Avatar
The 300's muffler is a rare thing theses days. Remove the end cap and add a tip and you have a nice performance upgrade over the 250's muffler. Also doesn't run a cat.
Old Apr 2, 2016 | 02:26 PM
https://www.kawasakiforums.com/forum...-wheels-36873/
Old Apr 2, 2016 | 10:16 PM
MaximusPrime's Avatar
You can use the kick start parts, if you want, on the 250.
Old Apr 3, 2016 | 01:43 AM
That's a good idea!
Pulled the engine apart tonight. It's shot. Crank shot, cylinder scored.
Old Apr 3, 2016 | 11:25 AM
Consider checking into one of three things with the cylinder:
  • can you get it re-plated and have a 300 big bore for your bike?
  • Can you have it big bored by Bill Blue for a 331 or 351 for your bike?
  • Do you want to sell it to Bill Blue for his going price? That could give you around 1/2 your purchase price back, I believe.
But personally I'd consider what it would cost and the time involved to build it back up and sell it, is there a profit to be made. Cranks can be rebuilt and cylinders either plated or bored. Obviously it is around $500 to make the cylinder a big bore if necessary. A crank rebuild isn't horribly costly if a new rod kit can be had, and I think they can. If the engine can be done for under $700 you have a running new engine 300 for a grand.
cpr1
Aug 11, 2012 01:19 PM
cpr1
May 30, 2011 04:44 PM
benwiggins
Mar 21, 2010 03:08 PM
WestOzKLX
Sep 8, 2008 02:14 PM
Divodave
Mar 21, 2007 08:39 AM
