02 klx300 wheels on klx250s
Probably been asked before..looking at a klx300r for parts and want to know if those wheels will swap to my klx250s
Maybe on an 06-07, but the front won't work with the speedo drive on the 09. The electronic drive is different from that of the mechanical.
Ok. I have an 06. I just picked up the bike with a blown motor for 300 dollars. I am going to tear down the bike and see what the motor looks like if its not bad, then maybe I'll fix the bike, if not I am just going to use the parts, header, wheels, ect. then try to part off the other stuff.
I was wondering if the klx300 suspension components are an upgrade as well. |
The 300's muffler is a rare thing theses days. Remove the end cap and add a tip and you have a nice performance upgrade over the 250's muffler. Also doesn't run a cat.
Originally Posted by toomanytoys84
(Post 528331)
You can use the kick start parts, if you want, on the 250.
(Post 528372)
Pulled the engine apart tonight. It's shot. Crank shot, cylinder scored. |
Consider checking into one of three things with the cylinder:
But personally I'd consider what it would cost and the time involved to build it back up and sell it, is there a profit to be made. Cranks can be rebuilt and cylinders either plated or bored. Obviously it is around $500 to make the cylinder a big bore if necessary. A crank rebuild isn't horribly costly if a new rod kit can be had, and I think they can. If the engine can be done for under $700 you have a running new engine 300 for a grand. |
