Oil in air chamber
Old Mar 19, 2018 | 12:47 AM
Kilroy's Avatar
Default Oil in air chamber
I have oil in my air chamber and also in my air filter housing where is this all coming from and is it supposed to be there this is a 2005 3010
Old Mar 21, 2018 | 06:03 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
Old Mar 22, 2018 | 06:58 PM
muggingleash's Avatar
Can you put some pic? Is there a lot of oil?
Old Mar 22, 2018 | 07:14 PM
If it's just some in the bottom, it is likely coming from the engine breather, which will be routed into the air box. No problem with that, it's the way things are. If it's a lot of oil you are probably blowing way too much out of the breather, usually due to overfill or if the rings are junk allowing too much blow by. My bet is on the normal oil in the air box due to breather. Also if you have an oil wetted foam filter there will be some drainage from it too. There ya go.
280zed
Nov 8, 2008 08:16 AM
Nobrakes
Nov 10, 2007 06:12 PM
progunrunner
Jun 20, 2007 03:52 AM
kawi636
Apr 4, 2006 09:26 PM
