I Finished tranny rebuild mule 4010 4x4 ask for advice
Old Jul 5, 2018 | 01:40 PM
Yami Oquendo's Avatar
Default I Finished tranny rebuild mule 4010 4x4 ask for advice
PoppapeteJunior MemberJoin: Jun 2018Posts: 2
1 day ago · #1
So I'm done with my 2011 mule ,4010 4X4 , so ask any advice if needed. I have 2 problems though if anyone can chime in. . The tranny easily engages only in differential lock or 4wd. Seems it needs the extra torque somehow to engage. Why? Since I had to replace the driven clutch and rebuild the drive primary clutch, my belt deflection is now 34mm. Rpm power is sluggish. How critical is this deflection?? Is this why it doesn't engage right away?? Is my tuning off now? Secondly, the dfi light stays on but I don't get blink codes when grounding the kds wire that's LG/BK stripe. The manual says to put ignition on. I assume this means don't start the engine. Any ideas would help me immensely since this job was a freebie and favor for a dear friend. Thanks a million
Old Jul 5, 2018 | 07:40 PM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. You may have better luck at this forum:
Kawasaki ATV and Mule - Kawasaki Motorcycle Forums
Old Jul 9, 2018 | 03:27 AM
Rob9876's Avatar
Also recently heard about this forum for ATVs: https://www.kawieriders.com/forum/
Okinawa
May 5, 2023 03:38 PM
Paul Leischner
Jan 14, 2019 08:32 PM
Jmill857
Aug 8, 2018 11:07 PM
aubreypric
Jul 9, 2018 03:28 AM
Green Truck
Apr 24, 2018 06:00 PM
