2005 Kawasaki 3010 630E
Rebuilt rear clutch about a year ago. Works great as far as going into idle and setting still while idling. Just now then you give it gas it acts like it slips a bit, then starts pulling good and strong. Belt measured out at 1-1/4” in width. It has just started this about a month ago. Before I rebuilt the rear clutch it wanted to not disengage always and belt would squeal and you had to knock it out of gear for it to set still. Finally got the idle set right and the clutch rebuilt and it was 90% better. It still once in a while still not release as it should and wants to keep pulling and it you hold the brake it will not release as it should. Do you think a new belt would help?? This belt has been on it for over 2+ years, before and after the clutch rebuild. Also I still have a hard gear shifting sometimes. It will act like the gears don’t mesh good as you shift from neutral to drive gear. I know she is old and has about 1150 hours on her but she runs great. I just changed all fluids in front and rear ends and engine oil and filter. It doesn’t use any oil at all.
Mule 610/3010
Dec 24, 2024 11:43 PM
