Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
wont start
Old Mar 1, 2008 | 02:55 PM
96_zxi's Avatar
Default wont start
hey guys working on a 96 1100zxi that i just picked up to add to the collection umm throw battery,plugs has hard time turnning over any suggestions before taking it to a shop
Old Mar 7, 2008 | 01:46 AM
apachetorpedo's Avatar
Default RE: wont start
buy a sea doo[8D]
Old Mar 10, 2008 | 08:52 AM
whitehendrix's Avatar
hard time turning over?
could be a driveshaft bearing...
i do believe theres a grease fitting on that?
not sure tho...
undo the shaft and see how freely the motor spins without a load attached. if it spins right up, look at the packing and the bearing on the driveshaft.
if the motor is tight, the i would suggest unlinking the cams to determine whether its in the top or bottom end.. then, spend accordingly.. lo
may be a rod or crank bearing, but if theres no noise, i'd almost not even worry.. could be a spun bearing tho from oil starvation or water contamination...
spun bearings don't always make noise..
i hope its something easy man. good luck!
and welcome to KF!!!
IQOUTLAW
Mar 23, 2010 02:33 PM
henryhoehandle
Sep 20, 2006 11:21 PM
kawibanshee
Mar 22, 2006 05:39 AM
DJNYC
Sep 21, 2005 04:00 AM
