Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
96 JS750 stand up Cuts off
Old Aug 12, 2008 | 11:24 PM
knoblitt's Avatar
Default 96 JS750 stand up Cuts off
My 1996 JS 750 cuts off when making hard left turn (going around bouys). I have gone through the ski looking for shorts, broken wires, pulled the stator cover to make sure the pick up was not loose or broken, Ohm tested the switches. The fuel is good, fuel lines are new, carbs mounted properly, spark is good, ( on the stand). You can ride the ski all day but if you try run bouys it will cut out. You can then immediately restart the ski and take off. I've checked the motor mounts thinking that the ski is flexing under the load of turning and binding the shaft some how. ANY IDEAS
halnative
Jan 6, 2008 06:54 AM
asudevil1881
Ninja 650R
Feb 7, 2007 04:25 PM
OwenSE83
May 9, 2006 02:58 AM
jaysonmatthews
May 9, 2006 01:28 AM
funtoos
Mar 28, 2006 09:30 PM
