Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
650 ts exhaust problems
Old Jul 29, 2006 | 11:20 PM
jeepguy's Avatar
Default 650 ts exhaust problems
i have had a problem with the rubber boot that conects the exhaust pieces together, i had bought exhaust hose from the local marina and it started to melt and leak today. does anyone know if there is something better to get or is there another problem that could be causing this? i don't know if it matters or makes a difference but it has after market exhaust on it also. please help!
Old Aug 2, 2006 | 11:20 PM
oneeye212000's Avatar
Default RE: 650 ts exhaust problems
the exhaust should be water cooled if im not mistakin. thats how it is on my 440 kawasaki stand up and thats how it gets away with running rubber hose between the exhaust pieces.
Old Aug 4, 2006 | 02:39 AM
jeepguy's Avatar
i checked some of the water lines that i could find, this may be a stupid question but how does the water get into the motor? and how is it pushed into the lines? by the impeller?
Old Aug 4, 2006 | 07:49 PM
ok, there should be a hole in your pump housing by your impeller, when the impeller is spinning it forces water through the hole and into a tube connected to the motor. hope this helps. when you find it, blow air through it and see if its pluged. also you should have a water vent on the side of your ski that pees out when your ski is running. this lets you know water is circulating, just like a boat moter.
Old Sep 23, 2014 | 05:00 AM
Derbytime1's Avatar
How much water should be coming out of the vent? I have hot water, but it comes out at about half the rate of taking a leak. Pretty technical lingo huh?
Trejo171
Jul 16, 2014 05:11 PM
Trejo171
Ninja 650R
Jun 22, 2014 06:39 AM
bmrconstruction
Jan 28, 2009 11:23 AM
tonk3@hotmail.com
May 16, 2008 02:51 AM
schnebelen
Jul 6, 2006 05:38 AM
