zzr400 carb
Old Nov 5, 2006 | 06:37 PM
darran400's Avatar
Default zzr400 carb
hi after following previous advice on here i have just cleaned out my tank and had the carbs cleaned out,i,ve put it back together and it starts,runs much better than before,a little lumpy and i,m struggleing to get a good tickover? could it be that i have put the throttle cables on the wrong way round? to be honest i never marked them before removing and had no clue which went where on reassembly, could this be a possible reason for it running a little eratic?does it make a difference which way the cables go?any help would be very much appreciated thanks darran ps i,m so useless at mechanical things if you hadent guessed
Old Nov 5, 2006 | 09:00 PM
BigRig18Wheeler's Avatar
Default RE: zzr400 carb
One cable is a pusher and the other a puller. I have never installed one incorrectly, so not real sure what would happen if they were??
But I wouldn't think it would cause the engine to run erratically. Can you describe the problem a little more? Is the bike running bad at idle, or thru the entire rpm range, or at constant throttle?
How far out are your af screws?
Old Nov 5, 2006 | 11:30 PM
You would definitely know if you installed the push/pull cables backwards.
Old Nov 6, 2006 | 12:47 PM
darran400's Avatar
hi and thx for your reply,the cables are on the right way around,it seems to be running a little fast,i cant get a even tickover below about 2000 rpm,i dont know anything about carbs to be honest so i dont know where the mixture screws are or how they should be set? i have a set of new plugs but dont know the gaps? the bike is a zzr400 by the way and thanks again for all your help darran
Old Nov 7, 2006 | 03:48 AM
NO prob...
I guess I am not real sure by what you mean tick over??
I am guessing that over 2,000 rpm it runs great? What year is your bike man and I'll find that plug gap for ya.
Old Nov 7, 2006 | 10:55 AM
darran400's Avatar
hi sorry about that by tickover i mean idle,it must be an english phrase lol the more i run the bike the better its gettin??? could the cables need adjusting after refitting? i took up all the slack on the adjusters but that made the throttle really stiff and tight,its still a little slugish on returning to closed when i release it,the bike is a 1990 zzr400 import to the uk and the gaps would be great if you can help thanks ever so much for all your time.
Old Nov 8, 2006 | 06:23 AM
Make sure your grip is not causing the drag for the spring return. Stiff and tight is not good either.
Arctra
Nov 21, 2010 11:48 AM
horizonod
Nov 15, 2008 12:38 PM
cokrkilr
Nov 22, 2006 03:28 AM
darran400
Nov 14, 2006 04:09 AM
