ZX10 B1 valve clearance. Please help
Old Jan 26, 2009 | 02:22 PM
teddybear's Avatar
Default ZX10 B1 valve clearance. Please help
Just bought a ZX10 but cant get a manual for it. As a ex Kawasaki mechanic i can sort the rest but i cant remember the valve clearances or what marks to line up on cam wheels to check them. Not worked on one of these for 15 years and memory not that good. Any help would be great.
Cheers teddybear
Old Jan 26, 2009 | 04:14 PM
BigRig18Wheeler's Avatar
http://www.repairmanual.com/motorcycles/1988/34/0/4935
http://cgi.ebay.com/ebaymotors/1988-...sQ5fLiterature
http://shop.wemoto.com/index.dyn?oid=1914625
theres a couple of manuals......dont know the specs off hand....My repair manual is 12 states away from me. Just moved and left it there in storage :-( ......I will have it shipped to me in a couple of more weeks if you dont get the specs by then.
Old Jan 26, 2009 | 06:21 PM
teddybear's Avatar
Thanks for reply. ill try those sites for manual but i want it running Now. Someone must know the clearances or have a manual to hand
Old Jan 26, 2009 | 10:25 PM
what year zx10?
Old Jan 26, 2009 | 11:07 PM
I do not have the '89 zx10 info. so am not sure on the specs. The '93 zx11 Standard Valve Clearance is IN. .13-.19mm, EX. .18-.24 for example. I checked in my 89 ZX7 manual and it too was different. Good luck in finding the required information.
Old Jan 27, 2009 | 05:05 AM
heres a link to a free manual....i couldnt get it to work for me, but you might try it.
http://www.manualz.info/paginas/manuals/kawasaki.htm
Old Jan 27, 2009 | 05:07 AM
and heres a manual you can buy and instantly download.
http://store.payloadz.com/str-asp-i....nd-detail.html
and another...... http://www.tradebit.com/filedetail.p...x10-motorcycle
and another.....this one is 6.00......http://www.e-junkie.com/shop/product/59116.php
Old Jan 27, 2009 | 05:57 AM
whitehendrix's Avatar
www.carlsalter.com may have it as well..
typically, it seems clearances sit at about .006" for intake and .008" for exhaust.. +/-.002
that is a safe basline if you're in a pinch.
use the T mark on the rotor for timing, as you know, #1 cylinder TDC on comp stroke.
the cam lines should fall in place.. not 10% sure what they are on that one, but typically, they're at 12 o'clock and 9 on the intake and 3 on the exhaust when you're dealing with a side-tunnel system..
good luck, hope maybe that helps a tiny bit, and welcome to KF!
Old Jan 27, 2009 | 07:04 AM
teddybear's Avatar
Thanks lads, got what i need, all sorted
Cheers teddybear
Old Jan 28, 2009 | 07:27 AM
sweet. Glad the link worked for ya!
If you have a pic of that thing, lemmee see it. I have a B3 series in my collection. my fav ride too...
Malves
Mar 23, 2013 09:33 PM
chris72a
Apr 5, 2008 01:39 AM
Sturgell
Nov 15, 2007 04:27 PM
stunner388
Oct 10, 2007 02:05 PM
Ginsu4u
KLX125 & KLX125L
Sep 10, 2006 09:49 AM
