To remove wheel paint use ______ ?
Old Jan 30, 2010 | 04:25 PM
lineblur's Avatar
Default To remove wheel paint use ______ ?
I bought a rear wheel for my ZX14 and it has the paint stripped from the tire bead up to the ridge where the spokes start. Looks GREAT!!! But now I have to make my original front wheel match it. I tried some gel house paint stripper I had in the garage, had no effect on paint finish. Is there a chemical product that will remove this type of paint.
Thanks
Old Jan 30, 2010 | 04:30 PM
Odimus's Avatar
you might have to use a real fine sandpaper...I used a gel to strip my aluminum MTB frame down with no damage to it...
Old Jan 30, 2010 | 04:38 PM
lineblur's Avatar
What type of gel did you use? Maybe the stuff I used was not the right type or strong enough. I assume Kawi wheels are powder coated.
Old Jan 30, 2010 | 04:48 PM
Odimus's Avatar
I used naval jelly...I know there is a how to somewhere in here about polishing the lips on the rims...not sure what they did but i think they had to use sandpaper...
Old Jan 30, 2010 | 04:52 PM
Odimus's Avatar
you can find some paint remover at an autozone for around 6$$$
Old Jan 30, 2010 | 08:14 PM
jeffzx9's Avatar
Or... you might try a 3M grit abrasive wheel on your drill. It looks like a scotch-brite pad, kinda. It won't dig into the metal, but will get rid of the coat.
Old Jan 31, 2010 | 12:24 AM
CDN ZX6r's Avatar
Wink
Thanks
Try some brake fluid and an SOS pad! Lol! I have had luck with a small dremel tool with a polishing/ fine grit head attached. I would tape up the areas you do not want to strip, and be careful! It's not as easy as many think, and doesn't look good if you screw it up!
Old Jan 31, 2010 | 12:26 AM
CDN ZX6r's Avatar
Yep! Pretty much the same as using the dremel on it.
Old Feb 1, 2010 | 04:11 PM
Fish_ZX10's Avatar
Thanks
If you have an o'reilly's in your area they sell a chemical made by Mar-Hyde. It is an aircraft coating remover. If you don't have an O'reilly's then you might just check your local auto parts store. I used this on my old 2007 zx6r to polish the wheels just like what you are trying to do. You have to be extremely careful to not get this on any part of your bike that you want to keep painted. Because within 2 or 3 seconds you can see the paint start to bubble up and it can then just be wiped off with a hand towel. The way I did it was to apply the paint stripper with a small brush just doing a little bit at a time. It took me a while because I didn't want to get sloppy and possibly mess up the look by spilling it or splashing it. Good luck! And enjoy the aftermath, because it will look awesome!
Sid Post
Jan 27, 2009 01:46 PM
snowburt80
Ninja 250R
Feb 24, 2008 10:59 PM
Apr 20, 2006 02:50 AM
Dagon
Ninja ZX-9R
Jan 10, 2006 04:31 PM
Dagon
Jan 9, 2006 03:16 AM
