To remove wheel paint use ______ ?
I bought a rear wheel for my ZX14 and it has the paint stripped from the tire bead up to the ridge where the spokes start. Looks GREAT!!! But now I have to make my original front wheel match it. I tried some gel house paint stripper I had in the garage, had no effect on paint finish. Is there a chemical product that will remove this type of paint.
Thanks
Thanks
Thanks
Thanks
Yep! Pretty much the same as using the dremel on it.
Thanks
Thanks
If you have an o'reilly's in your area they sell a chemical made by Mar-Hyde. It is an aircraft coating remover. If you don't have an O'reilly's then you might just check your local auto parts store. I used this on my old 2007 zx6r to polish the wheels just like what you are trying to do. You have to be extremely careful to not get this on any part of your bike that you want to keep painted. Because within 2 or 3 seconds you can see the paint start to bubble up and it can then just be wiped off with a hand towel. The way I did it was to apply the paint stripper with a small brush just doing a little bit at a time. It took me a while because I didn't want to get sloppy and possibly mess up the look by spilling it or splashing it. Good luck! And enjoy the aftermath, because it will look awesome!
