Once warm - starts smoking bad then stops
Old Nov 11, 2008 | 04:44 PM
Jutboy's Avatar
Default Once warm - starts smoking bad then stops
My 97 zx-6r(F) which is carbed starts and warms up fine. Once its warm is start pouring out smoke and then will shut off and refuse the start up again (runs for a second and then shuts off). I just had the carb cleaned and tuned about 2 weeks before this started happening.
Any ideas what is going on? I'm clueless.
Thanks - justin
Old Nov 12, 2008 | 01:26 AM
Did your mechanic use seafoam?
Old Nov 20, 2008 | 11:09 AM
williamr's Avatar
Sounds like it's far too rich. Either the choke isn't coming off, or the float heights wrong - easy to foul up if the carb's stripped. If it ran for a couple of weeks OK, then also suspect the float needle valve sticking and allowing the carb to flood.
Anything else is likely to be expensive.
Rob
Old Nov 20, 2008 | 03:48 PM
Talca's Avatar
what color smoke is it? black or blue?
meekie69
Apr 16, 2012 07:06 PM
kyrral
Jan 31, 2011 12:33 AM
JPJumpz
KLX110
Jul 14, 2009 01:41 AM
RDHJ
Jun 27, 2009 11:55 AM
adramalech
Apr 19, 2009 05:01 PM
