Fuel shutoff
Old Nov 12, 2008 | 10:22 AM
tf500's Avatar
Default Fuel shutoff
The petcock on my Vulcan 500 does not have an "off" position. How would I go about removing the tank without a major spill?
Old Nov 12, 2008 | 11:20 AM
Kohburn's Avatar
no off? doesn't seem right
either way to remove the tank you need to clamp the hoses from the tank going to the petcock before removing them from the petcock.
small vise grips usually work fine for me.
Old Nov 12, 2008 | 12:13 PM
yea... my buddys yamaha doesnt have an off.... thats crazy... no vise grips? maybe ya got something to plug the line and use the hoseclamp to keep it in...
Old Nov 12, 2008 | 04:40 PM
tanks with out a off position usally are vaccume fed. so for fuel to come out the petcock there would have to be a vaccume.
Old Nov 12, 2008 | 04:59 PM
eric is right,, vise grips could possibly tear the line... but they make plastic hose clamps for this reason.. your local napa or advance should carry them just for a couple of bucks
Old Nov 17, 2008 | 12:53 PM
williamr's Avatar
There should be thre positions on the tap - On, Res(erve) and Prime.
A tube from one of the carbs provides vacum when the tap is set to On or Prime. In either position the tanlk can be removed as the lack of vacum turns the tap off. No need to plug or clamp the line. No fuel flows if the engine isn't running.
Prime is needed to start the engine if it's been standing long enough for the fuel in the carbs to evaporate. It allows fuel to flow freely to refil the carbs before the engine is started. Don't remove the line with the tap set tp Prime.
Rob
Old Nov 18, 2008 | 06:41 PM
Zbike's Avatar
Rob
This is correct Just remove the tank. As long as its on "On" it will not drain unless the petcock is bad.
Old Nov 18, 2008 | 07:07 PM
94Ninja250's Avatar
Much to my unpleasant surprise, the petcock on my Virago dribbled when I unhooked the line from it. I disassembled the vacuum diaphragm assembly and cleaned it, and it works fine now. If you get some dribbling, it may just need to be cleaned. In my case it saved me about $70
Old Nov 18, 2008 | 10:06 PM
tf500's Avatar
Thanks guys
Old Nov 20, 2008 | 10:58 AM
williamr's Avatar
One small but significant typo in my post. The fuel is shut off when set to On or Res. Set it to Prime and petrol will come out.
Rob
