help with my kawasaki
Old Apr 25, 2013 | 03:11 PM
myersdalton's Avatar
Default help with my kawasaki
we have a 2000 Kawasaki prairie 400 4x4 that was given to us but it has been sitting for about 3 years with a hole in the radiator....we put a new radiator in it but when we run it we noticed it now has either water and radiator fluid in the oil chamber....any suggestions on what it might be and how I can fix it myself
Old Apr 25, 2013 | 03:34 PM
Brieninsac's Avatar
It could be condensation. I would strongly suggest changing the oil and fuel.
Old Apr 27, 2013 | 02:54 AM
moved:
Change the oil for sure as mentioned above. There is a good chance that the head gasket let loose when it got too hot with the bad radiator. You can do a leak down or compression test while the spark plug wire is disconnected to test.
Good luck and welcome to KF
Old Apr 27, 2013 | 07:28 PM
jeffzx9's Avatar
Agree with Drag^. Change the oil/filter. Double-check everything and change the head gasket if you need to.....just do it. I know; it's a PITA to do. Don't dick around, when they go, there's no "quick fix." (i.e., don't pour in a bottle of Barr's Stop Leak or other snake oil, OK?)
Welcome to the forums. Keep us posted. We'll help if we can.
Old Apr 30, 2013 | 05:31 PM
Thanks guys. I have never done this before and can't afford to take it to a shop to have done right now. Is it something an average person can do and do I need any special tools.
Old Apr 30, 2013 | 07:29 PM
charger2010's Avatar
hi there im new to this forum and i have a question...i have a 2003 Kawasaki Vulcan 500 and it is leaking coolant from the bottom of the water pump i have a feeling its the mechanical seals...if it is how hard is it to replace the seals
Old May 1, 2013 | 04:33 AM
fairly inexpensive specialty tools, yes
Once you own them, you will always have that tool for the next 20 or so more rides down the line that you may own.
Old May 1, 2013 | 04:53 AM
according to my vn800 manual, that mechanical seal is not too bad to swap out. But it also mentions to swap out the old impeller with a new one. Not sure if that is really needed or not.
Welcome to KF. Please start your own thread. That helps us old dudes remember where we last seen that post. LOL It will also help in the search section.
secretxsaint
May 25, 2010 01:27 AM
Prix
Sep 13, 2007 07:40 PM
Zoey
Apr 24, 2007 03:34 AM
rollie1960
Apr 12, 2007 06:31 PM
82ltd
Aug 26, 2006 06:02 PM
