Help!! My bike will not start!
Old Aug 8, 2008 | 12:09 PM
2low4u's Avatar
Default Help!! My bike will not start!
Ok, my dad ran my 06, 636 out of gas. Now that it has a full tank it still says its out of gas and will not start. From what im told the bike does not have a reserve so I am lost as to why it is doing this. If someone could please help me I would appreciate it. Im new to the bike community so all advice would be greatly appreciated.
Old Aug 8, 2008 | 06:03 PM
They dont have reserve??? I didnt even no that lol but Im a dirt type of guys anways someone here will be able to help you.. Try posting up in the 636 section.
Welcome to KF
and I used to live in Assville NC for awhile.. I worked at Prestige Subaru on Tunnel Rd..for 4 years But im back In WV now
Old Aug 11, 2008 | 11:28 AM
2low4u's Avatar
Now, I was told the bikes dont have a reserve but I dont know how reliable that sorce is.
Old Aug 11, 2008 | 02:58 PM
no reserve on these bikes. hey 2low try turing the key on listen for the fuel pump to prime then turn key off. do that a few times and see if it primes the gas into your injectors that way.
Old Aug 12, 2008 | 07:48 PM
RonInFla's Avatar
It should be carburated being an 06.
Is there a petcock fuel valve on it? If so, theres a PRI position. That means Prime, it forces the gas to the carbs. just remember to put the valve back to ON after it starts.
If its FI:
It didn't run out of gas, the connection for the fuel system (incl. the guage sensor) to the wire harness is dirty and not making a good connection(it happens). If there was a fuel pump problem, the guage would still read properly. If there was a fuel guage sensor problem, the bike would still run.
Aer-goe:
Both components (pump & sensor) share a common harness, which is connected poorly.
Get some "dielectric grease" and use it on every connector you can find.
Old Aug 13, 2008 | 03:49 AM
check this out.
http://fiche.ronayers.com/Index.cfm/...Fuel_Injection
Old Aug 13, 2008 | 04:16 PM
zzrick's Avatar
Carburetors went away in '03 for the 6r...right?
Old Aug 16, 2008 | 12:21 AM
RonInFla's Avatar
hence: both suggestions.....
mfcordova2008
Nov 17, 2009 12:49 AM
iggymagoo
Ninja 250R
Jul 18, 2008 02:37 AM
dvr979
ZZR 600
Jan 20, 2008 07:55 PM
intense_05_636
Oct 13, 2007 07:06 PM
