bike will not start
Old Jan 19, 2008 | 05:50 PM
dvr979's Avatar
Default bike will not start
I have an 06 zzr600. I was on the way to work the other day when it shut down at a stop light and wouldnt start. It doesnt even turn over when I press the starter switch. It was low on oil(almost empty) so I put some oil in it and tried that. Still wouldnt start. I jumped the solenoid and it started right up. Is this a bad starter solenoid? Or is it a bigger problem? Thanks
Old Jan 19, 2008 | 06:49 PM
zzrick's Avatar
Default RE: bike will not start
How are the connections at the battery? I know it is probably not the answer, but mine started to do that for a while and it was a loose bolt causing intermittent contact.
Old Jan 20, 2008 | 01:42 AM
dvr979's Avatar
Thanks for the response, the battery and the connections are good to go.
Old Jan 20, 2008 | 06:44 AM
I like to start with the starter button. Then progress from there. Checking voltage and making sure that switches and relays are doing there job.
Old Jan 20, 2008 | 07:55 PM
zzrick's Avatar
Yep I agree, start with all of the simple stuff and rule those out first.
mfcordova2008
Nov 17, 2009 12:49 AM
2low4u
Aug 16, 2008 12:21 AM
iggymagoo
Ninja 250R
Jul 18, 2008 02:37 AM
intense_05_636
Oct 13, 2007 07:06 PM
