bike will not start
Old Jul 17, 2008 | 10:57 AM
iggymagoo's Avatar
Default bike will not start
need some help when I hit the start button it just clicks at the magnetic switch area; I got my battery tested and its good "I was told"; called the Kawasaki shop and they said put a screwdriver across the main leads on the magnetic switch and nothing happened would not start so mechanic told me the magnetic switch was bad it bike would not start with the screwdriver; so put new mag. switch on bike yesterday and still will not start.... HELP
Old Jul 17, 2008 | 11:00 AM
iggymagoo's Avatar
Default RE: bike will not start
By the way if I push the bike and pop the clutch will start right up no problem
Old Jul 18, 2008 | 02:37 AM
dillon's Avatar
take a hammer and tap on the starter motor. Alot of times starters will get dirt or grit in the motor from wear and it can bind the motor up. If that works it could happen again so you may want to save up for a new starter motor.
mfcordova2008
Nov 17, 2009 12:49 AM
2low4u
Aug 16, 2008 12:21 AM
dvr979
ZZR 600
Jan 20, 2008 07:55 PM
intense_05_636
Oct 13, 2007 07:06 PM
