Going to pod filters, what about the case vent?
Old Mar 27, 2008 | 01:31 AM
blacktalon606's Avatar
Default Going to pod filters, what about the case vent?
I'm going with pod filters... but I can't find one to fit the case vent. Can I just plug it or do I have to find a filter for it somehow?
Old Mar 27, 2008 | 08:33 AM
whitehendrix's Avatar
Default RE: Going to pod filters, what about the case vent?
NO!!!lol.. don't plug it..
tis there for a reason, sir.[8D]
i've seen alot of times where guys wil just get a tiny little air filter from auto zone or a store of similar nature and terminate the hose or vent with said cute lil filter.
while this doesn't block off any oil and recirc it back into the motor(to the combustion camber..), it will retain most of the oil, and most importantly, vent the case effectively.
if you block the "pcv" (on anything, actually.. car or bike)
you'll lose ring seal.. ring flutter occurs (normally and typically) 9000rpm whether ya like it or not. this can be mapped and adjusted with a flow meter and a closer 2nd ring gap.
if the pressure were to build up, chances are you'll experience very sever blow-by and flutter at a very low rpm and under high load.
bad stuff.
but yeah. the turblow, kleen-air mod, and individual filter guys usually just cap the vent with a tiny little filter made for the vac lines for cold-air intakes for hondas and such.
incabiker
Feb 10, 2016 12:35 AM
sup_uni
Dec 27, 2007 06:41 AM
xtremef4i
Ninja 250R
Oct 22, 2007 06:11 AM
fivepointnine
Ninja 250R
25
Aug 24, 2007 04:08 AM
FRIEK
Dec 13, 2006 05:59 AM
