FRONT BRAKE CHANGE
Old 05-24-2008, 01:33 PM
preemo_21's Avatar
Default FRONT BRAKE CHANGE
i took off my front calipers, pushed the pistons back and replaced my pads. placed them back on the rotors, hooked the lines back up and bled them and still no brake pressure when i squeezed the brake lever. any ideas?
Old 05-24-2008, 02:22 PM
KevyzToy's Avatar
Default RE: FRONT BRAKE CHANGE
How many times did you squeeze the lever? Once you push the pistons back in you need to pump a few times to build the pressure.
If you did that, then you still have air in the lines. Re-bleed.
Old 05-24-2008, 09:21 PM
yup, yup as kevin mentioned. Also wipe down the discs for any oil residue removal.
Old 05-30-2008, 01:42 PM
preemo_21's Avatar
when i squeeze and hold in my front brake lever, do i let the air out on both calipers or one caliper at a time?
Old 05-30-2008, 08:03 PM
C.Hern5972's Avatar
Try like KEV said. Put your bike in a stand spin the whell and pump the brake several times. Might be as simple as that. I did mine about 2 weeks ago and thats what solved my issue.
Old 06-01-2008, 04:16 AM
preemo_21's Avatar
my brakes r fine now. just had alot of air in the lines. thank you all, big help to me and my zx7. i'll b posting pics up here this week
Sid Post
04-22-2008 04:26 PM
EMS_0525
12-29-2007 12:15 PM
doktorroo
06-23-2007 07:18 AM
cwgoff
01-30-2007 09:23 PM
Red636guy
04-24-2006 09:50 AM
Quick Reply: FRONT BRAKE CHANGE
