Anyone change brake pads??
Old Dec 27, 2007 | 11:23 PM
Default Anyone change brake pads??
While i was taking off my sprockets i looked at the brake pads... looks like i need to replace them... bikebandit says they are gonna be like 33$ for front and 31$ for the rear pads... The bike has 7800 miles on it now. anxious to see what 13/45 does...
That washer that you have to bend to remove the front sprocket... how many of you have replaced it.... this will be the second sprocket up front, and im not sure if i should replace it...
Old Dec 28, 2007 | 12:31 AM
ZX1100F1's Avatar
Default RE: Anyone change brake pads??
I replaced my rear brake brake pads after getting some chain lube on the rear disk they never worked right after that, I replaced with a set of EBC pads and they feel much better then the stock pads ever did.
I switched out my front sprocket and then later went back to the stock sprocket, the second time I switched out sprockets I installed a new washer, the dealer had it in-stock for under $4 and it just seamed like a good idea to me even though I hit that nut hard with an air gun.
Old Dec 28, 2007 | 12:41 AM
The washer is pretty pliable but work hardens after a couple of changes. I like changing it out every 2 sprocket swaps.
Old Dec 28, 2007 | 03:49 AM
EvildoerZX10R's Avatar
Under $4 bucks, change it out every other time seems like cheap insurance. If you are doing mostly dirt riding you will love the sprocket change. But if you are on the street a lot you might be like me and always looking for that "7th" gear. I like it for the riding I do.
Old Dec 28, 2007 | 04:04 AM
ORIGINAL: EMS_0525
Let us know what ya think....I'm running 14:49 about the same as 13/45 maybe 46 but regardless, ....... I'm thinkin of going to 14:47 or 46 ..... lookin forward to your ride report ems.
Old Dec 28, 2007 | 04:07 AM
Hehehehehe
Old Dec 28, 2007 | 04:36 AM
You tease!
Old Dec 28, 2007 | 04:45 AM
ORIGINAL: deej
Hehehehehe
Ha, Ha Ha ......deej has sand fleas ...... you better watch it deej....ever see Starship Troopers....those bugs can get mean....lol
Old Dec 28, 2007 | 04:55 AM
Toss the $'s into the jar, and things are back to normal.
edit: Kids and betime.......
