FRONT BRAKE CHANGE
FRONT BRAKE CHANGE
i took off my front calipers, pushed the pistons back and replaced my pads. placed them back on the rotors, hooked the lines back up and bled them and still no brake pressure when i squeezed the brake lever. any ideas?
RE: FRONT BRAKE CHANGE
How many times did you squeeze the lever? Once you push the pistons back in you need to pump a few times to build the pressure.
If you did that, then you still have air in the lines. Re-bleed.
Sid Post
04-22-2008 04:26 PM
