Engine bogs down when rolling on the throttle
Old Sep 20, 2011 | 12:25 AM
jeffzx9's Avatar
I think you're getting some crud in your secondary jets. You have to literally take a piece of fine wire and poke it through the jet "hole" to get the debris out; soaking it just doesn't work. There may be some residue lurking in the carbs, somewhere. Doubt it's the fuel filter. Some guys will tell you to "just run the hell out of it" to clear the crud. I've not had any luck with that method. My bet is on crud.
Old Sep 21, 2011 | 02:07 AM
Southpaw's Avatar
Thank you for your advice, I'll try it out and see what comes of it!!
Old Oct 7, 2011 | 04:43 AM
Southpaw's Avatar
I have it running good again, I let it sit idleing for 2 hours tonight. I runs pretty good, the idle is a little bouncy but it doesn't conk out. It revs all the way up. Have some backfire when I do that and at first I saw a flame flash out the tailpipe everytime I reved it but I don't really see it anymore. I have alittle bit of hesitation in the midrange but it sounds good. Next I gotta fix the clutch issue!
Old Oct 7, 2011 | 06:45 PM
Work on the fuel issue and get that completed. Hit up the valves and get things tidied up. Then move on to the clutch during that time. Just my opinion
Old Oct 8, 2011 | 12:38 AM
Southpaw's Avatar
I ran it and ran it, drove it around for some time around the blocks. It's running good and starts right up. Very little hesitation in mid range but it's working itself out. I've never messed w cylinder valves before, I'm mechanically inclined but never dabbled in valves lol!
Old Oct 9, 2011 | 01:19 AM
hahaha, congrats on the progress none the less.
Old Nov 26, 2011 | 12:02 AM
Southpaw's Avatar
The bike runs damn good now from the carbs, engine, and clutch. I learned a bit with my first bike. What it came down to was patients, keep it to the basics to trouble shoot. Worked for me atleast and now I have a bike that runs damn nice for an 85' ninja 600r!
Old Sep 15, 2016 | 01:26 PM
fraserninja's Avatar
I have the same problem. I cleaned carbs and jets and added a large filter because of dirt / dust /mud in float bowls. But I did find a partial solution. I just peel back the #1 carb rubber into the airbox and it revs to 11k. 13k? is over redline is it not?
Yes I am using a lot of gas too. Also if I hold my hand over the carb mouth it will spit back gas so suspect that the carb is blocked. Manual suggest buying a new carb. The internal very small passages that can not be cleaned without major work like drilling an access hole might be a solution but I am not that desperate yet.
Also check your diaphrams for holes in the rubbers
Attached Thumbnails Engine bogs down when rolling on the throttle-ninja-carb-rubber-mod.jpg
Southpaw
May 1, 2012 02:41 AM
Southpaw
Apr 27, 2012 04:06 AM
Fordbrian333
Dec 3, 2011 03:28 AM
OGmackPLRcool
May 6, 2009 11:24 PM
macfast12002
Aug 13, 2007 07:14 AM
