Clutch????
Old Oct 8, 2008 | 02:45 AM
87kawi500's Avatar
Default Clutch????
I have an 87 ex500. When I start the bike after it has been sitting for more than 10 hours or so and put it into first gear the bike stalls. I can not get it into neutral unless the bike is running. I hold in the clutch lever all the way when I attempt to restart the bike and then the bike lurches forward while the clutch in all the way. I usually have to try 2-3 times to get the bike started and each time the bike lurches forward. Any ideas on whats going on? Do I need to replace the clutch or make some sort of adjustment? I have no issues when it comes to shifting between gears. It's just when I try to start the bike and put it into first gear for the first time.
Old Oct 8, 2008 | 07:07 AM
BigRig18Wheeler's Avatar
I would check the easy and usual suspects first. Oil condition/level.... Clutch play/adjustment.
Old Oct 8, 2008 | 09:47 AM
williamr's Avatar
Sounds like burnt oil gumming the plates together. Try an oil change. If that doesn't fix it, strip the clutch and clean the plates - emery cloth on the friction plates. While you're in there, check the plates for warping.
Make sure there's 2 - 3 mm cable free play at the lever.
Rob
Old Oct 10, 2008 | 12:23 AM
I agree with the basic checks according to your manual as well. Along with the maintenance intervals.
jcbowling1985
Ninja 250R
Oct 19, 2012 05:35 PM
RayCour
Jul 21, 2010 10:35 PM
deej
Oct 2, 2008 09:58 PM
JERSEY
Apr 23, 2006 08:30 AM
