brake light not luminating.
Old May 4, 2006 | 07:49 PM
02kawipawi6's Avatar
Default brake light not luminating.
I just purchesed a 2002 zx-6r not 636. the brake light doesn't come on with the hand brake and i really have to give force on the foot brake to luminate it. Are they suppose to luminate w/ the hand brake? if so, what should i be checkin?
Old May 4, 2006 | 07:59 PM
Notstock's Avatar
Default RE: brake light not luminating.
Yes it should always come on when you hit either brake. If you can get it to come on by pulling in harder on the brake handle then check the sensor or switch that turns it on. It must be out of adjustment.
Old May 4, 2006 | 08:27 PM
frrogger1's Avatar
im with notstock on this...check to see if the sensor is ouot of adjustment...for the foot brake there should be an adjuster just above the rearset
Old May 4, 2006 | 08:53 PM
Notstock's Avatar
ORIGINAL: frrogger1
Where is it on the front though, I was trying to think about it and for the life of me can't. I may have to drive home and look, it's pissing me off [:@]
Old May 4, 2006 | 11:18 PM
frrogger1's Avatar
give me a few min and i will go take a look on my bike....mine is an of but i think it is the same on the 02
Old May 5, 2006 | 04:48 AM
frrogger1's Avatar
well i was wrong about adjusting the front sensor...i looked on my bike and in the owners manual....you might have to replace the front brake sensor
Old May 5, 2006 | 05:09 AM
frrogger1's Avatar
well i took some pics to help you with adjusting the rear brake sensor
Old May 5, 2006 | 05:13 AM
frrogger1's Avatar
also i think that you turn the nut counter-clockwise to make the brake light turn on with less pedel travel and clockwise to turn on with more pedel travel.....if that makes sense
Old May 5, 2006 | 05:40 PM
hey, i will go check it out now. THanks for all your help. I'm gonna contact the seller and see if he can help me out w/ the front sensor. now i don' need to worry aobut being rear ended. THANKS AGAIN!
Old May 7, 2006 | 07:05 AM
funtoos's Avatar
i had the same exact problem with my 2000 9r... it turned out to be the little switch right under the front break.. it was like 15 bucks..
Tdizzle
Apr 18, 2009 06:29 PM
ntloser
Oct 23, 2006 02:07 PM
05zx_6rrider
Oct 1, 2006 07:34 AM
funtoos
Mar 28, 2006 09:04 PM
BigRig18Wheeler
Mar 6, 2006 08:39 AM
