Changing out OEM Brake light
Its no to bad take off the two cover on the side of the seat, the seat, passenger seat, take out all the screws (and plug things on the bottom) on the tail section and signal lights. I had the clear alternative smoked integrated tail. There is one wire (that I soldered and shrink wrapped) for each signal light. The main plug for the brake light needed a little bit of force to connect not quite a perfect fit. Then put it all back togethor but mak sure you check to see if it works. Mine came with resisters to slow it down the blink rate but it was slow enough without.
VERY easy as long as you have some knowledge of motorcycles! Just take your time and it will go great! I did mine in 10 min in a parking lot of a motorcycle shop...I just couldnt wait to TEAR off those ugly *** black things!
make sure you grab that little rubber boot on top of the original, i forgot that on mine and the new tail light was flopping all over the place, had to take off the whole tail agian and pit that pice in
I have a Lockheart Phillips clear/integrated light. Moved all the original mounting hardware from the old one to the new one, and no matter what I do it pops loose and there's about a 2mm gap between the fairing and top of the light. Any suggestions?
