BIKE WON'T STAY RUNNING
Old Oct 3, 2006 | 12:43 PM
preemo_21's Avatar
Default BIKE WON'T STAY RUNNING
OK I TOOK ALL MY FAIRINGS OFF MY 93 ZX7R ABOUT A COUPLE WEEKS AGO INCLUDING MY AIR FILTER BOX..I HAVEN'T STARTED UP MY BIKE UNTIL YESTERDAY AND IT KEEPS CUTTING OFF...I TURNED THE CHOKE ALL THE WAY UP AND IT'LL STAY ON UNTIL I TURN THE CHOKE BACK DOWN THEN IT'LL CUT OFF AGAIN...WHAT'S WRONG WITH IT??? COULD IT BE THAT I TOOK OFF THE WHOLE AIR FILTER BOX OR COULD IT BE THAT I HAVEN'T STARTED IT FOR A COUPLE WEEKS??
Old Oct 3, 2006 | 05:26 PM
Notstock's Avatar
Default RE: BIKE WON'T STAY RUNNING
Time to clean carbs and make sure all the vac hose's areconnected.
Old Oct 3, 2006 | 07:49 PM
markmeinteil's Avatar
Not having the air box on could make a considerable difference. Sounds like your bike is running extremely lean.
Old Oct 4, 2006 | 05:08 AM
So is the air box on or removed now?
Old Oct 5, 2006 | 01:07 PM
preemo_21's Avatar
ITS REMOVED CAUSE I'M GETTING EVERYTHING PAINTED THIS WINTER...SHOULD I TAKE ALL THE FLUIDS OUT AS WELL?
Old Oct 5, 2006 | 09:18 PM
If you are referring to winterizing your bike, then no, you don't need to remove all your fluids. Just put all fresh fluids in your bike as well as gas stabilizer in a FULL tank. If you drain your tank, you can get rusting problems.
leenhouston
May 15, 2010 06:47 PM
oldryder
Jul 22, 2008 03:19 PM
joeyv69ragtop
Ninja 500R
23
Jun 4, 2007 01:34 PM
tbspyder
May 3, 2007 08:24 PM
crazyace
Apr 22, 2007 07:30 AM
