bike not starting..can hear clicking sound
Hi, I have a 94 Ninja 250, and the bike no longer starts, but there is a rapid clicking noise coming from a small round component with a red 30A fuse and connector on top of it. Pics are below. Is this the starter or solenoid? Sorry..im a tech newbie. TIA
http://www.facebook.com/photo.php?pi...p;id=580620713
That would be an electrical solenoid. It is probably good, but I bet your battery is eitherbad or has low voltage. Try charging up your battery first and then see if the bike turns over. (Make sure you only use a trickle charger.)
What voltage are you reading at the solenoid? How old is the battery. Good connections? From seeing a rusty resevoir connector thought I would ask.
