250 ZZR Back Shock bottom out
Old Jul 25, 2007 | 02:20 AM
ripper_zzr's Avatar
Default 250 ZZR Back Shock bottom out
I find that whenever i go over bigger bumps and speed bumps on my 250 ZZR myback shock seems to bottom out. How can i adjust that so it wont do it anymore.
Old Jul 25, 2007 | 02:37 AM
mmi86's Avatar
Default RE: 250 ZZR Back Shock bottom out
Stiffing up the compression about 3-4 clicks
Old Jul 25, 2007 | 03:49 AM
A 250 ZZR? and doing bigger jumps? and you are complaining about a street shock? By the way, do they make a 250 ZZR?
Old Jul 25, 2007 | 05:53 AM
markmeinteil's Avatar
The ZZR is the Canadian/rest of the world 250 model. They are much nicer than ours in the states.
If your Ninja is like the 250R sold in the U.S, the rear shock is non-adjustable. You should be able to upgrade to the adjustable 500R shock though.
Old Jul 25, 2007 | 05:55 AM
No modifications are needed to install the 500R shock.
Old Jul 26, 2007 | 02:50 AM
That is a purty 250!
Old Jul 26, 2007 | 03:11 AM
Told you so![8D]
Old Jul 26, 2007 | 11:35 AM
KevyzToy's Avatar
Sounds like to me you don't have your suspension set properly. You need to get the sag set for the rider weight, both shocks and forks. Go here to help you get them set right. http://www.sportrider.com/tech/146_0006_susp/
Get a couple of buddy's to help you out. Should only take you about an hour to get it set right. Then some minor tweaking on the rebound and compression and you will be good to go.
nhjake
Jun 11, 2015 10:07 PM
Mike Fournier
Mar 2, 2015 05:36 AM
CousinLarry
Mar 9, 2011 12:56 PM
horizonod
Nov 6, 2008 12:48 AM
bgillette78
Apr 25, 2007 04:24 PM
