06 Ninja won't start
Old Dec 15, 2010 | 02:19 AM
rharmon38's Avatar
Default 06 Ninja won't start
Earlier today I took a spill on the snow coming onto my driveway. After I had wheeled it into my garage, I noticed it had been leaking gas, found a puddle of it several hours later. Now it will not start. It looks like it leaked out of the overflow. There was fuel loss but there is still some in the tank. When I go to start it it makes a ticking noise and will not crank. Any suggestions?
Old Dec 15, 2010 | 09:14 AM
hmm, 06 what? may be the tip over switch after a tipover like that. Hit up your manual for that issue for the none start. Welcome to KF
Old Dec 17, 2010 | 04:10 PM
jeffzx9's Avatar
Check your tilt switch^, key switch, wiring between key switch and starter button assembly, and any signs of pinched-stretched wires. Might even be some moisture or a loose ground on your battery.
Any serious damage; guessing a mirror and side plastic? OUCH!
Old Dec 17, 2010 | 11:37 PM
driver1's Avatar
chanje the oil and spark plugs
IdRatherBeJeepin
Nov 4, 2008 06:10 AM
kmoulton
Apr 3, 2008 03:39 AM
u8myrice
Ninja 250R
Aug 16, 2007 03:52 PM
mlee24
May 28, 2007 06:22 PM
maubee
Nov 20, 2006 05:31 AM
