98 ninja won't start
Old Nov 18, 2006 | 07:59 AM
maubee's Avatar
Default 98 ninja won't start
I tried starting my bike and it wouldn't start then my battery died. Changed the battery and rode it a couple times and now it won't start. What could be the problem. It sputters but it wont start. It also backfires a few time when I try to start it. Please help. Thanks
Old Nov 18, 2006 | 08:30 AM
markmeinteil's Avatar
Default RE: 98 ninja won't start
Sounds like it might either be flooding out, or could have dirty jets.
When you try starting your bike, never roll on the throttle, only use the choke if necessary. Using throttle upon startup is an easy way to flood the engine.
If your jets are dirty, it will be impossible to make the engine run right.
Obviously there is a wide range of variables that could cause your one problem, but the carbs tend to be the culprit more often than not.
Old Nov 18, 2006 | 08:50 AM
maubee's Avatar
You know what, I think you might be right. I usually roll the throttle when I start and I also use the choke. Would this be an easy problem to fix, could I do it myself?
Old Nov 20, 2006 | 05:28 AM
maubee's Avatar
My bike just started and I drove it around the block. don't know what I did just took off the gas tank looked at the air filter and touched a few wires.
Old Nov 20, 2006 | 05:31 AM
Great! glad to hear it's running now.
Ninja Warrior
Sep 7, 2009 03:15 PM
IdRatherBeJeepin
Nov 4, 2008 06:10 AM
kmoulton
Apr 3, 2008 03:39 AM
u8myrice
Ninja 250R
Aug 16, 2007 03:52 PM
mlee24
May 28, 2007 06:22 PM
