06 6r tank removal
Old Jan 13, 2006 | 05:30 AM
600rrjoe's Avatar
Default 06 6r tank removal
Whats the process for removing the tank for a PCIII install? Thanks
Old Jan 13, 2006 | 08:09 AM
MAD KAW's Avatar
Default RE: 06 6r tank removal
wow i've done it once but here goes.
1. take off rear seat
2. remove plastic from under the front seat, both sides
3. remove rear cowl
4. remove front seat
5. on the middle of the frame you'll see a bolt with a plastic black washer. those have to come off.
6. then remove the bolt in front of the tank
7. once you get all that stuff off you could tilt the tank back by pulling the front end up
8. and there you have it easy access under the tank, now ir you have to take the tank all the way off. well your on your own on that
one... good luck i hope this helped....
Old Aug 27, 2010 | 05:59 PM
Jdizzy47's Avatar
i have a 98 zx6r and need to remove the tank without letting the vacumm pull all the gas out ? any thoughts
Old Aug 27, 2010 | 07:22 PM
Turn your fuel tap to the off position. I am not seeing in the manual where any vacuum will be pulling fuel out. (it is not mentioned)
Welcome to KF
Old Aug 30, 2010 | 07:23 AM
Prom's Avatar
Should be no vacuum to speak of with the engine off. Welcome to KF!
MaximusPrime
Sep 15, 2012 10:29 PM
Brieninsac
May 8, 2012 04:28 PM
brnrbber18
Apr 10, 2010 07:24 AM
doughrek
Feb 3, 2008 12:49 AM
hicktown
Jun 28, 2007 04:08 PM
