06 6r tank removal
wow i've done it once but here goes.
1. take off rear seat
2. remove plastic from under the front seat, both sides
3. remove rear cowl
4. remove front seat
5. on the middle of the frame you'll see a bolt with a plastic black washer. those have to come off.
6. then remove the bolt in front of the tank
7. once you get all that stuff off you could tilt the tank back by pulling the front end up
8. and there you have it easy access under the tank, now ir you have to take the tank all the way off. well your on your own on that
one... good luck i hope this helped....
3. remove rear cowl
doughrek
Feb 3, 2008 12:49 AM
