05 ZX6R Front Brakes lose pressure - no leak
Old Dec 6, 2010 | 09:00 PM
Beachgrad05's Avatar
Question 05 ZX6R Front Brakes lose pressure - no leak
My bike sat for a bit and when I went to ride it, the front brake had no pressure. Upon examination, there was no evidence of a leak of brake fluid. Bled the brakes and it was fine for a bit then due to weather the bike sat again for a while and again no brake pressure. No evidence of leaks again but somehow air is getting in the system. Anyone else experience this with their bike and can point me in the right direction as to possible problems to trouble shoot?
Old Dec 6, 2010 | 09:09 PM
replace the rubber on the res? A busted diaphragm will cause issues. or the seals on the caliper. (last thing since there are no leaks). The diaphragm, the seal and making sure that all air is out of the system is my thinking. good luck edit: welcome to KF
Old Dec 9, 2010 | 01:10 PM
williamr's Avatar
Most likely air in the system. Also worth checking the master cylinder seal as this would allow fluid to pass back into the resevoir without actual loss.
Rob
Old Jun 9, 2012 | 03:28 PM
trini2dabone1's Avatar
this is the same issue i'm having, lever looses pressure after sitting for 3 or 4days after bleeding manually. no fluid/air back filling the reservoir, so i'm assuming my master cyl. ok? How can u make sure if there's an issue with the master cyl.? thanks..
Steven05ZX636
Jun 29, 2010 02:29 PM
ninjarunner06
Apr 25, 2010 06:39 PM
Jacked
Aug 2, 2009 12:01 AM
evoc6711
Ninja 650R
Oct 17, 2008 12:03 AM
KDXmike
Sep 20, 2008 02:53 AM
