DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
How to repair old school brass carb floats from a KZ 1000
Old 06-21-2006, 01:23 AM
c10's Avatar
c10
c10 is offline
Default How to repair old school brass carb floats from a KZ 1000
Here is a Pro ET bike I maintain and tune for Dorey Racing . # 2 cylinder was wet fowling the plug and filling the motor with fuel.
I found a hole in the float causing it to sink allowing fuel to flow all the time on the # 2 cylinder.
After carb removal and disassembly you can shake the floats and tell if fuel is in them . Once you find the bad float you must remove all the fuel before re sealing the hole .
Putting the float in the sun for an hour usually takes care of this for you . Next using a bowl of alcohol
submerge the float and watch for air bubbles . Mark the area and clean well after using some sand paper to rough up the area of work .
Using a soldering gun heat the float and apply some solider to seal the hole . Allow to cool a few minutes and check for leaks.
Last cheak your float height and reinstall all parts . Repair is done.
[IMG]local://upfiles/32/C9F4AE0ED54242768DCB87EBF44585B2.jpg[/IMG]
[IMG]local://upfiles/32/A8AE449B3F204B78B9C159A7F7B93E7B.jpg[/IMG]
[IMG]local://upfiles/32/53A8E4AA5BAE4F6B9F42C5F0CA500E83.jpg[/IMG]
[IMG]local://upfiles/32/89DD8BF039B3408FAD74CDC0A5838EEE.jpg[/IMG]
[IMG]local://upfiles/32/3142D2A2786B48A384D09A554B023152.jpg[/IMG]
Old 06-21-2006, 01:28 AM
c10's Avatar
c10
c10 is offline
Default RE: How to repair old school brass carb floats from a KZ 1000
Here are a few extra pics of the 1977 KZ 1000 Pro ET bike . Mid 9's and after I put the 1078 APE kit with 12 to 1 compresion it will be
in the low 9's high 8's in the 1/4 Mile .
I will post a how to install the 1078 kit in a month or so after I get the cylinder back from the machine shop .
[IMG]local://upfiles/32/EF539B7FE9AE4F9BA7C37FE5541899B0.jpg[/IMG]
[IMG]local://upfiles/32/DA5812D9DB374C30924382933F3970B7.jpg[/IMG]
[IMG]local://upfiles/32/F735FAF39749439AADADF95C8B601A4D.jpg[/IMG]
Old 06-22-2006, 12:01 AM
BigRig18Wheeler's Avatar
Another good write up.....
A bike in the high 8's is pretty dam impessive!! I would love to see a vid of that thing in action if you ever get the chance...
Old 06-30-2006, 07:33 AM
Manning's Avatar
any specific kind of solder? will silver solder work?
Old 07-01-2006, 12:34 AM
c10's Avatar
c10
c10 is offline
here is a link . And yes silver solder .http://www.artmetal.com/enrique/wrou...ng/solder1.htm
deej
12-01-2008 05:18 PM
noob_rider
08-16-2007 11:43 PM
joe sprocket
09-21-2006 05:47 AM
kerNol
Ninja 500R
08-30-2006 11:42 PM
CALISAKI
04-05-2006 11:18 PM
Quick Reply: How to repair old school brass carb floats from a KZ 1000
