How to repair old school brass carb floats from a KZ 1000
Here is a Pro ET bike I maintain and tune for Dorey Racing . # 2 cylinder was wet fowling the plug and filling the motor with fuel.
I found a hole in the float causing it to sink allowing fuel to flow all the time on the # 2 cylinder. After carb removal and disassembly you can shake the floats and tell if fuel is in them . Once you find the bad float you must remove all the fuel before re sealing the hole . Putting the float in the sun for an hour usually takes care of this for you . Next using a bowl of alcohol submerge the float and watch for air bubbles . Mark the area and clean well after using some sand paper to rough up the area of work . Using a soldering gun heat the float and apply some solider to seal the hole . Allow to cool a few minutes and check for leaks. Last cheak your float height and reinstall all parts . Repair is done. [IMG]local://upfiles/32/C9F4AE0ED54242768DCB87EBF44585B2.jpg[/IMG] [IMG]local://upfiles/32/A8AE449B3F204B78B9C159A7F7B93E7B.jpg[/IMG] [IMG]local://upfiles/32/53A8E4AA5BAE4F6B9F42C5F0CA500E83.jpg[/IMG] [IMG]local://upfiles/32/89DD8BF039B3408FAD74CDC0A5838EEE.jpg[/IMG] [IMG]local://upfiles/32/3142D2A2786B48A384D09A554B023152.jpg[/IMG] |
RE: How to repair old school brass carb floats from a KZ 1000
Here are a few extra pics of the 1977 KZ 1000 Pro ET bike . Mid 9's and after I put the 1078 APE kit with 12 to 1 compresion it will be
in the low 9's high 8's in the 1/4 Mile . I will post a how to install the 1078 kit in a month or so after I get the cylinder back from the machine shop . [IMG]local://upfiles/32/EF539B7FE9AE4F9BA7C37FE5541899B0.jpg[/IMG] [IMG]local://upfiles/32/DA5812D9DB374C30924382933F3970B7.jpg[/IMG] [IMG]local://upfiles/32/F735FAF39749439AADADF95C8B601A4D.jpg[/IMG] |
Another good write up.....
A bike in the high 8's is pretty dam impessive!! I would love to see a vid of that thing in action if you ever get the chance... |
any specific kind of solder? will silver solder work?
here is a link . And yes silver solder .:)http://www.artmetal.com/enrique/wrou...ng/solder1.htm
