DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
(carbs) 83 kawasaki kz550 ltd c4
Old Jun 21, 2012 | 05:26 AM
unformalpenguin's Avatar
Exclamation (carbs) 83 kawasaki kz550 ltd c4
I just got the bike and of couse the previous owner was an idiot, so im fixing hes stupidity. That being said i need to re-jet the carbs. I was just going to buy a jet kit from dyno and ive asked a few shops if it will work but its onlt for the 80-82 models so i need to know if this jet kit will work on my 83 ill post a link to the jetset at the end of this post.
My carbs a TK, Teikien, I dont know much about kawasaki but it is a strong bike just needs a little tlc please someone help if i can take the easy way out with the jet kit i will if not then i guess ill start with the guess work and get the jets right.
Also i need a decent answer soon im hoping to get this taken care of with in 3 days.
Thanks for your help heres the link...
Dynojet Jet Kit - Kawasaki KZ 550 LTD (80-82) DJ-2305 2305
Old Jun 21, 2012 | 12:36 PM
jeffzx9's Avatar
Welcome, unform. Not sure on the jets; not familiar with TK carbs. Keihin and Mikuni's are more my flavor. Take a good look at the driveshaft; make sure seals and joints are tight and right.
Glad to have you with us. Post a pic or three of your ride!
Old Jun 22, 2012 | 03:05 AM
I have not heard of that carb. So I do not know much on it either. A carb is a carb, so if you know the carb basics, it is just that. Welcome to KF and good luck.
Old Jun 22, 2012 | 04:16 AM
Thank you!
The guy that said that an 82's jet set would work on my 83 said that mikuni made tk carbs but like i said im not familiar with this carb either. Ive done carb work its tedious but easy, but if the jet set will actually work then should be just easy you know.
I just want someone to say yes they do ive done that lol.
The jet set runs $125, and im not looking to spend that on a maybe...
I just took the bike out for a 3 and a half hour drive to and from and it did great its running a little hot which is now my new worry but through process of elimination im at the carbs running to lean, meaning new jets lol.
So if you have info on this or know someone that does please let me know
also the air filters the moron had on are screwed and i will have to replace im a big fan of k&n air filters would anyone know the demintions for there flat oval filter it runs $35 has a life time and i only would need two of them they cover 2 carbs each. I had these on my 81 suzuki ans it was truley impressive the difference they helped achieve...
And lastly since the long trip on the bike i have a slight knocking soundin the bottom of the crank case, Not vaulves and not pistons knocking sounds more like somethings moving around a piece of something if anyone has an idea what this could possibly be let me know it might be nothing but better safe than sorry. And on this note there has been no lose of power still starts and still runs so the knocking or my head after such a long day isnt hmm pulling from power or prefomance... Maybe just a tip of a gear had that happen before...
Anyways Thanks again for replying and you welcome to the site!
Old Jun 22, 2012 | 04:28 AM
This is the make and model of the carbs im looking at...
Teikei
K22P-2C
Alsp another idea I have my carbs still from my 81 suzuki gs 550 you think i could fit them on and make them work for my kaw.
Old Jun 24, 2012 | 11:54 PM
Read the plugs and pull out your stethoscope to listen for that knock location. You are correct that you are probably running hot due to the lean carb mains and other setpoints.
unformalpenguin
Jul 11, 2012 08:57 PM
SilverThunder
Jun 27, 2010 10:02 AM
pacman714
Jun 14, 2010 02:58 PM
kwandrsn
Nov 17, 2007 03:51 AM
Sailormilan2
Apr 20, 2007 06:14 AM
