1600 Classic clatter
Old Sep 28, 2006 | 07:24 AM
Vulcan Rider's Avatar
Default 1600 Classic clatter
Hello to all. My '03 1600 Classic has developed an embarassing clatter. It sounds like it is coming from the front end of the engine. Hard to tell exactly when you going down the road. The bike runs great, with no abnormal noise except when I accelerate ( i.e.-to pass someone). Mainly you hear this clatter when the bike is in 4th or 5th gear and only when you give it some more throttle. Any suggestions? I run Amsoil 10-40 oil and almost always run 91 octane gas. I'm thinking fuel injector problem and praying that it's not engine trouble. Haven't taken it to the shop yet. Thanks to those who respond.
Old Oct 1, 2006 | 08:29 AM
BigRig18Wheeler's Avatar
Default RE: 1600 Classic clatter
Welcome to the forums man...
Tensioner maybe? Valves? Tough to call with out hearing it, ya know... GL to ya.
Old Oct 6, 2006 | 11:47 PM
condor55's Avatar
I have a 06 meanstreak 1600, I had a clatter at sertain times while acceleratin, I did find out that it was the grill in font of the radiator that at sertain RPM's vibrates and resonates on the frame.
I removed the radiator frame and inserted some rubber bushings to isolate the gril from the frame,and presto, clatter gone.
check if that is the noise you hear.
Old Oct 6, 2006 | 11:53 PM
condor55's Avatar
I removed the radiator grill cover and inserted some rubber bushings to isolate the grill from the frame,and presto, clatter gone.
Old Dec 10, 2006 | 03:42 AM
06Nad1600's Avatar
I thought the 1600's were to run on 93 octaine or higher only?
Old Mar 29, 2007 | 08:38 AM
VULCAN0L0GIST's Avatar
Did you recently get a new helmet or quit wearing one at all ?
Old May 9, 2007 | 06:05 AM
drgriffi1's Avatar
Sticker on mine says 90 octane or higher, it's a 2007 Nomad 1600.
Old May 9, 2007 | 06:29 AM
streaker's Avatar
I have a 07 meanstreak 1600 and it has a nasty clatter too. It is the front headlight vibrating in the casing. Check that. It moves very easy. Hope you can figure it out.
Old Jun 26, 2007 | 12:26 AM
tony3542's Avatar
I've also got a 03 classic with alot of chatter/buzz.I just got it 2 weeks ago and still trying to pin point it.It does it in all gears at a certain RPM.I know its coming from the front of the bike,I'm thinking it might be the big crome cover on top of the gas tank,speedometer cover???
thanks,
tony
horizonod
Jan 3, 2009 09:26 PM
bodraleadz
Jun 26, 2007 04:49 AM
knopper81178
Jun 14, 2007 03:35 PM
kevster
Jun 5, 2007 07:23 PM
jnjcaldera
May 17, 2007 07:18 PM
