Oil Leak / 5 mm machined hole ??
Old 08-19-2011, 03:48 PM
Green hornet's Avatar
Default Oil Leak / 5 mm machined hole ??
1999 Nomad....I have oil leaking from a machined hole on both cylinders, both holes are located near the power valve. Front cylinder 5 mm hole is located on the head itself next to the fins on front left center and the back 5mm hole is in the cylinder itself next to fins near exhaust flange. What are these holes for? do i need to plug them? I have fixed the stanard rocker PLUG Leak, i am quite sure i have oil come from these holes. Holes do not appear to have threads. Please help!! Major oil leak on front cylinder and blowing all over bike and me, This sucks!!!!!! THANKS for your Help!!!
Old 08-20-2011, 11:37 PM
Do any of these numbers/parts indicate what you are mentioning?
OEM Parts Kawasaki Vulcan 1500 Nomad (VN1500-G1) 1999 CYLINDER HEAD - Cheap Cycle Parts
Old 08-22-2011, 06:05 PM
Yes, but pic does not show in detail hole location. I will take photo of hole and post tomorrow, maybe tonight. Thanks for your involvement; I really need to get this fixed. I depend on this for my daily commuter.
Old 09-26-2011, 03:54 AM
leoems's Avatar
hey,i have a 99' nomad that just started leaking oil in the same area on the rear cylinder, next to the tensioner. did you get any ideas/repairs? if I look into the rear hole with a mirror, appears hole goes in pretty far.possible weep hole. Let me know whats up-- thanks
Old 10-18-2011, 03:38 AM
leoems's Avatar
the "holes" are drains for the spark plug "wells". I unscrewed both spark plug cups and replaced the leaking o-ring seals-----no more leaks!!
IDRIDR
02-13-2018 11:43 AM
incabiker
02-10-2016 12:35 AM
Green hornet
09-16-2011 02:10 AM
chris636
11-03-2007 01:44 PM
Quick Reply: Oil Leak / 5 mm machined hole ??
