Bernie's timing mod results ! (cue Hallelujah Chorus)
#51
So Richard, what is the bottom line on the timing mod ? Can you quantify the results? Do you think you've picked up 1 or more HP ? Do I need to plan to pull my flywheel ?
We ( old tuners) know too much advance can completely kill top end performance - you seeing that at all..?
#52
Look into modifying the bracket that holds the pick up or slotting that bracket if you don't want to pull the flywheel.
#53
I now have two identical weight lightened flywheels; one with the 3mm nose extension to advance timing (on the bike now), and one that is unmodified except for being lighter.
I'll get around to a direct comparo between the two sometime in the future.
Simonm3
06-09-2014 02:35 AM
