how much oil?"
Old Dec 23, 2009 | 07:04 PM
kxrider863's Avatar
Default how much oil?"
how much oil do i need to put in my 2 stroke rm250? its a 1999. and the ratio is 32.1 and im changing the engine oil and i just need to know how much to put in and i went to autozone and got 2 cycle engine oil witch i belive will work write me back with sum answers !!!
thanks nick
Old Dec 23, 2009 | 10:53 PM
You have Tranny oil and you also have two stroke oil to mix with your gas. You will have a sight glass for the tranny oil level, go half way while the bike is level. The required 32:1 recommendation will be listed on your two stroke oil container. Just breathe and follow directions and you will do just fine.
Old Dec 25, 2009 | 04:19 AM
kxrider863's Avatar
ok the side of the bike that im putting it in is on the right, and what i bought from autozone was it the right stuff? if not what kind should i get..??
Old Dec 25, 2009 | 05:12 AM
hmm, wow let me go look in my manual. (I am trying to be sarcastic just enough for you to be prepared on how to work on your ride properly and not to hurt yourself.)
Actually, I do not have that manual for that ride either. But 10w-30 or 10w-40 standard oil works good on the kawi trannys and should fare well in the RM
Old Dec 27, 2009 | 03:54 AM
wedge's Avatar
do a search on a RM/SUZ site they will mostly know and share common problems. only a few of us (KFr's) here have had RM's
Old Dec 27, 2009 | 04:00 AM
yeah, my last two smoker suzuki was a TS and a TM. Been awhile, but good luck on your manual search.
Old Jan 3, 2010 | 03:43 PM
kx slaughter king's Avatar
if you got got it at auto zone and it dosent have their label on it its more than likely fine. if you want high end stuff buy the manufacturers oil at the dealer... other wise anything you buy at pretty much anywhere that sells oil is plenty good. just stay away from small 3rd party names. like if you go to gibbs for gas and you realize you need oil to and all they have is lubemax 2cycle oil, dirve a little further (to the shell/citgo, or even possibly a pennzoil/autzone) and grab a bottle of castrol or mobil and youll be ok and so will your bike.
cpr1
May 30, 2011 04:47 PM
cpr1
May 30, 2011 04:44 PM
work
Feb 6, 2011 02:06 PM
zzrotceh
ZZR 600
Feb 1, 2011 06:23 PM
davehayward1
Sep 20, 2010 07:28 AM
